Topic: Speedo not showing speed (Read 3764 times) previous topic - next topic
oooh i havent thought of that maybe that's the problem yeah ive removed the cluster. ive recently changed my headunit could that maybe be a problem?
[SIGPIC][/SIGPIC]My Dream LOL
Quote from: jcassity;349390
where does it say that?  profile says bird
user has no sig so i had to look when you said that.
Nope, your right. I must have scrolled too fast, saw 20thanivser. and thought he started the thread..... MY mistake.
your up for a challenge if the cluster has not been out before in order to measure continuity up each individual flex print run becasue its really difficult to verify without the whole blasted thing taken apart.
might as well add a jumper wire to "W2" inside the physical speedo module and make it worth your while.  that way you can go past 85 on english setting.
My break was right in the middle of that whole mess but i had to use a magnifying glass to see the breaks.
hmmm ill see what I can do, tommorow is a new day, haha
seems like its a fuse since the clock stopped working too
go to page 21 of the evtm,,,
shop manual is confussing me right now,,
verify ckts associated with the speedo are ok.
