Topic: TC Hood Scoop (Read 603 times) previous topic - next topic
TC Hood Scoop
Does anyone have a spare set of TC hood scoops they'd be willing to sell? I was burning off some old tires and my fan clutch apparently seized up. Took out the water pump, the fan, fan shroud and probably the radiator, plus sent fan parts out through one of my hood scoops. Seems like a good excuse for a electric fan conversion.
Anyways, needing at least one scoop, willing to buy either a single or a pair. Believe the broken one is passenger side, will check if someone is willing to sell a single.
Thanks,
Chris
87 Thunderbird 5.0
Engine: 97 p-code explorer block, heads, and intake; 88 HO cam, 1.7 RR's, A9P, Kenne Bell 2.1 Flow/Blow 8psi, 42lb injectors, LMAF, 75mm TB, Tuned by Don Lasota
Trans: 02 Stang 4r70w with Baumann TCS
Suspension: Front: 03-04 cobra springs and struts, TC rack. Rear: CHE arms, ChuckW shock mounts, Bullitt springs and shocks
5 bolt with 95 mustang front and mark vii rear.
TC 3.73 L/S rear
03-04 SVT Cobra 17x9's with 275/40r17's.
TC Hood Scoop
I'll sell a pair for $30 shipped. let me know if interested
John
TC Hood Scoop
Sounds good to me. PM me your paypal address, assuming you use paypal.
Chris
87 Thunderbird 5.0
TC 3.73 L/S rear
TC Hood Scoop
pmed the info for you
thanks
John
