Topic: 2.3 Ignition Issue (Read 1633 times) previous topic - next topic
2.3 Ignition Issue
My 88 TC has an ignition break up problem above 11 pounds of boost. I have a boost control valve so I have set the boost at 10 psi and everything is normal. Timing is set at 12 degrees, plugs and wires are new. Dist cap looks good. Here's the kicker, if I shrink the plug gap below .030 and advance the timing, it runs good up to 15 psi or where ever it starts to detonate depending on air temp. I'm thinking a coil. Any suggestions would be appreiciated.
[SIGPIC][/SIGPIC]      STEVE ;)
2.3 Ignition Issue
Use only motorcraft ignition parts on the 2.3T  Sounds like youve narrowed it down, coil,plug wires.  What brand of wires?
Mike
2.3 Ignition Issue
I had a set of Taylor wires on it originally, but then put a brand new set of Motorcraft wires on it and it didn't change.
2.3 Ignition Issue
sounds like the boost is blowing out the spark. id say gap em down a bit and see how she runs.
Got that fox rash again!
-Resident smartass! :ies:
2.3 Ignition Issue
Quote from: Blackbird1;348375
where were you trying to set the gaps? generally, there is no reason to be wider than .030" on these motors.
2.3 Ignition Issue
Plug gap spec is .032-.036. That would be my reason.
