Topic: 3.8 timing cover gasket (Read 5245 times) previous topic - next topic
clean it off and smear some silicone over where it's leaking.. you may stop it for the time being
The front cover is full of oil grime so I'm having a hard time finding exactly where the leak is :hick:.
on my LS , i have an inline short section of EMT tubing , inline with my heater core return hose.
on this tube i have installed a tire air nipple but its the kind with two gaskets and a nut.
This is where I add air pressure to the cooing system then listen or look for leaks.
in your case,, i would leave well enough alone.
there is a tool just for this and its a modified radiator cap so you can inject air into your cooling system and do the same thing I am doing, although it has a guage to watch the pressure as well.
