Topic: Carb size calculator (Read 9418 times) previous topic - next topic
GT40's are small, but still 10 times better than the E7's, especially when ported lol
Quote from: hypostang;346869
First you need to be honest with yourself as to what you want and how much do you want to spend .
/QUOTE]
This becomes the heart of it.  In the evolution of most grassroots builds, it's often missed, because what is really wanted costs considerably more.  Unfortunately, for most, the reality of that fact comes after spending cash on mismatched parts.
There are countless times when grassroots builds are complete and the performance expectations are never achieved.  Then more cash is spent chasing the expectation.  Not cost effective, but certainly a learning experience (which is what life's about...).
The most common mistake is the wrong cam and valve springs.  The right ones can make a pretty basic pile of parts really sing.  That's the area where an experts opinion is worth every dime.  It's where I'd spend my hard earned cash.  But that's just my opinion based on what I've learned in my years of chasing performance.
There are lots of ways to build an engine and for the most part they'll all start and run.  "Run" is a relative term!
Quote from: 86T-bird;346883
Exactly ..    how do *YOU* want it to run .:burnout:
Couple of sites on camshaft theory and design (you may have to dig around on their sites to find the links to the tech info but its there):
Buddy Rawls (Cam Guru)
http://wighat.com/fcr3/index.html
Camshaft Innovations (Jay Allen is another Cam Guru)
http://www.camshaftinnovations.com/
Flowtech Induction (Ed Curtis - or should I say "The Ed Curtis"?)
http://www.flowtechinduction.com/index.htm
It all starts with the cam as it is the brains of the motor.  Cam selection is just more than having enough clearance between the piston and valve.  You have to take into consideration the heads, intake, compression ratio, and the rpm range of the motor.  Once that is taken into consideration then you select a carb or size the MAF, TB, and injectors.
This is why a plan is so critical to the build.  Budget is a consideration but if you have a plan then you can start looking for the parts at which time you may find some really good deals on used parts which helps you achieve the budget goal.
Darren
This is a project motor, I dont even have a car for it yet. I might change my plans and build my 289. Its a complete short block. I have a really nice set of ported closed chamber 58cc 302 heads for it too. I dont want to was the GT40s on this motor cause they're going on the Cougar when I do the HO swap. Im not worried about the carb right now, I just thought the link would help people pick the right carb for their build. I have a 650 D-pumper and a 600 single feed, so I'll use which ever one that runs better. As for the cam in a 289, it will either the matching Edelbrock torker or a Lunati Voodoo.
I did some more digging and found what I was really looking for here:
http://www.compcams.com/Company/CC/CamRecommendation/CamHelpNew.aspx
Download the CamQuest 6 and play with it.  The more you use it the better you will understand how the software works and you can really dial in a good cam for your combo.
Darren
Plus 1 for the cam being important
 Get a game plan to include: Displacement,heads,intake,headers(size and lenght),trans,gears and the weight
 of the car and palnned use of the car
 Just my 2cents
 Plus the carb calculator fell right in line with what I use on my son's car. We took a 750 CFM a 950 CFM and a 1000 CFM carb to the track and change them and made back to back passes to decide which worked best.
 the 950 was good for right at a tenth in the 1/4 on motor
If money's really tight, don't spend on parts that don't match. Wait and get the right ones. A $50 cam that works poorly is a lousy buy, particularly if you have to buy another to get it run right.
General guidelines I have learned:
Example #1: Big heads, single plane intake, big carb, big exhaust, little cam (custom), power from idle to as high it's built to spin. Good idle, lots of vacuum, good gas mileage, easy to live with.
Example #2: Small heads, small carb, dual plane intake, small exhaust, big cam like a Stage 2 (OTS) = soggy low end, peaky power band, low vacuum for power brakes, poor idle, crummy gas mileage and miserable to live with.
I've done builds at both ends. Example #2 really sucks. Spent all the cash on trying to get togehter and running and don't have funds to get it to run right. Example #1 takes more saving and planning, but it's sooo much more satisfying to have it work right!
We all have our learning curves. I did #2 builds until I learned better. Wish I knew better earlier! I would have save a bunch of time & money.
Hope you have good luck which ever one you choose.
I would like to add an op-ed to this.... #2 type build if done with some thought can be just fine for some people ,it depends on what the the car is going to be used for.
If going as fast as possible is your goal then #1 all the way ,
But for a daily driver that you just want a *little* more than stock that will NEVER see a track if the proper cam is chosen to match all the other components #2 type of build works just fine and when I say #2 build , I think Gt40s are "small heads " but they can be cammed to get decent mileage and vacuum as well as increased power with OTS parts .
Engines are not "one size fits all" First you need to be honest with yourself as to what you want and how much do you want to spend .
Again I say" the single biggest decision is the cam"
You're gonna get more driveability out of a #1 type buildup as opposed to a #2.....
Need proof?  Take a lightning 351 and throw a TFS stage 2 or an equivalent in it that will have proper PTV clearance.  Change NOTHING else on it.
Now take an LS1 and throw GM's stage 1 hot cam in it -- which BTW is smaller than a TFS2 -- and tell me which one when put on an engine dyno will run away from the other in both peak and average power output.  Average power output is gonna get you down the track faster as well as being more street friendly -- ESPECIALLY in front of an automatic transmission equipped car.
You can get #2 to work, but chances are you're gonna spend more than you want to.
Quote from: V8Demon;347960
Did you even read my entire post ?
 I confused on the point you are trying to make by quoting it .
 I said # 1 was better but a #2 would be ok for some people if done with  forethought and being honest with what they want .
 Not everyone wants to /can spent $1000 or more on a set of heads plus $300 or $400 on a custom cam.
I dont need "proof " for something I already agreed with, or is this an SBFtech type of response where there is only one way of doing things or it is "wrong"
Quote from: turbo_88_XR7;347977
:laughing: SBFtech reference :rollin:
  .....what did I miss?  :dunno:
Go check out http://www.sbftech.com/ and you will understand.  Kind of similar to what you will find at http://www.corner-carvers.com only they are nice at sbftech.  You were warned so just lurk...do not post until you are 100% you want to go down that road.
What I don't even get is the refercence to a LS1 motor.  Its bad enough to try and debate different sbf combos let alone another brand of motor.  Granted the LS series of Cheverolet motors are good (not great) but that is a whole other can of worms.  Keep the thread on topic and post useful information pertaining to the thread and the OP.
Darren
because sbftech is good for info, but much better if you want to be ridiculed
Quote from: hypostang;347968
Wow...Do you always get so bent out of shape?  I fail to see where I insulted you.
No wonder I hardly ever post here as this place USED to be able to accept other opinions and sources of input.  Funny you mention SBFtech because for your ridicule of them you sound as if any advice that would come from there would be shunned by you simply because of it's source.
Pot meet kettle.
If you did a #2 build and it worked for you -- meaning you were satisfied with the results -- then great.  The average person doing a build on #2 will spend more money than they initially intended in my views/experiences.  Some get lucky.  Most won't.  Those who get lucky have made enough builds before/had the right person help them.
I've seen fully assembled sets of TFS and AFR heads go for far less than $1000.  The trick is to be patient and wait for a used set.  And $400 for a custom cam is a small price to pay to tie everything together correctly.  If one cannot be patient enough to wait for the parts they want to meet their budget, perhaps they should find a new hobby.  If $400 is too much they should DEFINITELY find a new hobby.
I realize that not everyone has X amount of dollars to spend on a build --  again this goes into priorities and whether or not one should even THINK about a teardown/buildup. You should never go into a build wanting to spend X and only having X.  You should always have a surplus -- NO EXCEPTIONS.
What I don't even get is the reference to a LS1 motor.  Keep the thread on topic and post useful information pertaining to the thread and the OP.
Research the head flow on an LS1 motor's heads as opposed to GT-40 iron heads and you'll see ;)  How does any of what has been discussed here NOT pertain?
Just because I didn't directly discuss carburetors?
i disagree with your statement about guys who don't have the money to spend $400 on a cam finding a new hobby, that's just asinine.. there's nothing wrong with a $100 cam for the guy on a small budget, or even a $50 used cam.. so what, it won't give him everything a $400 custom cam will, but it's better than stock and still gets the job done, just not as well
