Topic: 87 cougar got attacked by a gremlin (Read 3923 times) previous topic - next topic
Well the other day, I was driving home from work and my stereo died, the numbers on my speedo were gone and my power door locks don't work.  A week ago my alternator went so I replaced it, and I was running a fm transmitter off my laptop to my stereo.  Any ideas?
Thanks
Eric
87 cougar 3.8
99 jimmy
sounds like you blew a fusable link somewhere
1971 Camaro Blown 640ci
1988 T-Top Mustang
1980 Mustang coupe
1988 Thunderbird TurboCoupe
Previous Thunderbirds:
1988 Sport
Or the ignition switch, believe it or not. I had the same symptom in two cougars, and both were the ignition switch. Not the key hole, the electrical switch on the underside of the column.
Check the fuses first, but if all else fails, I vote ignition switch.
CoogarXR : 1985 Cougar XR-7
A bad ignition switch also caused those issues in the Sport not long after I got it. A few dollars and a few minutes later,all good.
I HATE electrical gremlins!!
2017 Subaru Outback
2007 Lincoln MKZ
1990 Ford F250 / Banks turbo diesel
Never thought of the ignition,  any way to troubleshoot it?
87 cougar 3.8
99 jimmy
Replace it. If it's bad, we all know what the ford ignition switches can do...
sounds like a plan.  thanks everyone
Eric
87 cougar 3.8
99 jimmy
The ignition switch is only about $13 and about 15-20mins of work.
1988 T-Top Mustang
1980 Mustang coupe
1988 Sport
I went to the local canadian tire, they kid behind the counter wasnt sure what I was talking about, kept telling me that the only ignition switch is the one that you put your key in.  did i miss understand and this is the one you are all talking about?  Or is there another name for it?
Thanks all and Merry Christmas
87 cougar 3.8
99 jimmy
lol that kid is stupid.. what you put your key in is the ignition lock cylinder or ignition tumbler as some call it.. the switch is behind that
awsome, thanks gents,  Ill take a look at those links when i get done work, darned work computer keeps saying its blocked bc of spyware/malware sources; vehicles.
87 cougar 3.8
99 jimmy
well, I FINALLY got around to changing the switch today and no difference, I am going to tear into it again next time I get a chance to see make sure its plugged in all the way. (time is scarce right now) In the mean time, any other ideas?
Thanks
Eric
87 cougar 3.8
99 jimmy
also, power mirrors arnt working is there a set location of all fusable links (a map or chart saying what acc. are on each link?)
Thanks
87 cougar 3.8
99 jimmy
