Topic: Strut Tower Brace (Read 7189 times) previous topic - next topic
Strut Tower Brace
Watch ebay, I think I only paid $80 for mine and it was like new with all the hardware and it even came in the original box.
Strut Tower Brace
hmmm. materials would probably cost me about $15. And I can score a bender when I need.. Looks like another winter project to me
Strut Tower Brace
I found mine at the junkyard for 13 bucks. Looks just like Vinnie's except mine isn't red. Had it for a few months now and still haven't installed it yet (gotta get it blasted and powdercoated) so I can't say how it affects handling but the general purpose of it is to stiffen up the front end a little.
FOXLESS!!
1994 Lincoln Mark VIII
Strut Tower Brace
With you being able to make it yourself I don't blame you. And you can bend it to fit however you need it to that way.
Strut Tower Brace
It did stiffen it up a bit.
 I was also told to lift the frontend off the ground with the tires hanging. I think the guy that told me that said if there's any sag in the front this will pull it back out. Then while it's still in the air put the brace on. I went ahead and did it that way, I don't know if it made a difference but I did it anyway.
Strut Tower Brace
It will basically keep the shock towers from moving inward on compression in hard cornering.  Makes the car more predictable in the turns.  If you already have good full length subframe connectors in the car I doubt you would notice any more rigidity in the chassis.
Darren
Strut Tower Brace
Is there a manufacturer of a strut tower brace that can be used on a car with or without cc plates?  I don't want to buy a strut brace if I later have to s it or sell it because I can't use it with camber/caster plates.  I'd be willing to pay a bit more for one that can be used with or without CC plates.
Strut Tower Brace
They have absolutely nothing to do with the CC plates.
Darren
Strut Tower Brace
Strut tower braces r comparable with car with or without cc plates. There is no interference issues to worry about!
