Topic: Opinions on my combination (Read 7237 times) previous topic - next topic
Quote from: mtgmike;345616
FYI, Im pretty sure you are going to want to wait to do the computer until you do the full ho/engine swap. Dont swap computers and mass air and try to drive with the SO engine. Different firing orders.
Just when I think I'm ready to go ;)  OK, so now I'm back to the disc brake/5 lug mods.
1974 Falcon XB-GT Coupe
1988 Thunderbird Sport
1962 Thunderbird convertible
1971 Mustang Mach1 429SCJ
Ok. Hold on. I am running a A9L pcm with the stock thunderbird 5.0L engine harness (including the O2 harness) with a mass air conversion and a AOD. The only issue I have is a shiznitty idle due to no tune on the 351w yet. I have not burned up any pcm's yet
:burnout:
Quote from: 86caprirs;345834
I haven't either,  I think our o2 harness is different than the stang.  Also I think it would have been a topic here over the last 10+ years if it did have to be repined.
our 02's are in the manifold, mustangs are in the H-pipe, they are longer.
Duckin' agents like we was trapped in da matrix!
The earlier link breaks it down. You have to just check if there is power to a certain pin on the harness while cranking the engine. I havent checked mine yet. We may all be fine, who knows.
87 Thunderbird LX
65mm tb, exploder intake, iron gt40 heads, 1.6 rr, a9l mass air swap, 9.5" Billet Dirty Dog TC, Built AOD, 4.10's, 31 spline TLoc, Superior Axles, full sn95 five lug swap.
