Topic: Build Sheets (Read 8732 times) previous topic - next topic
Build Sheets
Quote from: daminc;346794
might have never even had one.... another possibility
true.. i'll go with that option lol
Build Sheets
My build sheet was impossible to retrieve once I found out where it was.  It turned into a c of removing teeny pieces of paper from between the metal....
Build Sheets
Quote from: V8Demon;346850
That was my problem. But if i put them all together I can pretty much make out everything it says.
Build Sheets
Oh no, mine was severely faded/yellowed as well.
Build Sheets
That's why I left mine where it is... It's safer right where it sits
Build Sheets
Quote from: daminc;346789
That's where a majority of them are from 87 and up... There's a thread about this somewhere.... might be a sticky by now
under the rear seat, and in the trunk are also other places they were put... Along with above the gas tank in a lot of earlier cars
Here's the thread you are probably thinking about.
http://www.foxtbirdcougarforums.com/showthread.php?25246-Original-cars-owners-documentation
If anyone has buildsheet info please add it to the thread listed.
tbirdregistry.com
26480
27373
Build Sheets
That's it....I searched, but couldn't remember what the thread was called...
Thanks
Build Sheets
Quote from: daminc;346909
Thanks
I search for things I know that are there all the time and always come up empty, lol.
Build Sheets
There was another thread about build sheets where I posted a scan of mine. I can't find that thread.
My 83's build sheet was under the driver side carpet. I took the seat and carpet out to weld the floorpan and found it there. Here is a link to it full-size:
http://midohiovideo.redirectme.net/coogarxr/buildsheet.jpg
CoogarXR : 1985 Cougar XR-7
Build Sheets
Some of the codes are identical to Capri/Mustang, which I am more adept in decoding, but here is what I could do with CoogarXR's build sheet.
Some of the items that I marked as [blank] may have not been available for the 1983 Cougar.
VIN
1ME = Mercury vehicle manufactured in USA
B = active belts, no airbags
P = passenger car
92 = Cougar 2-dr sedan
F = 5.0L V8 engine
9 = VIN check digit
D = 1983 model year
H = Lorain Assembly
674910 = 74,910th 1983 Mercury scheduled for production at Lorain Assembly
Build Sheet
Line A
Rotations Number - 0473 = trim & chassis rotations #0473
Line - W = Cougar model line
VIN - P92DH674910 = [decoded above]
Body Type - 66D = Cougar 2-dr sedan
Tops, Roof - [blank] = no sunroof
Paint, Body - 9P = Desert Tan exterior paint color
Paint, Accent - [blank] = no tu-tone paint
Int, Trim - AH = cloth seating, low-back front buckets (A), Desert Tan interior trim color (H)
Int, Dev - [blank] = no interior trim deviation
Type of Order - 2 = stock (dealer) order
Region/District - 33 = Cleveland district sales office
Special Order - [blank] = not a special order
Line B
Engine - F = 5.0L V8 engine
Trans - T = AOD transmission
Air Cond - M = manual air conditioner
Engine, Tag Number - 3K328AA = 1983 model year (3), Thermactor emissions (K), 302 engine (328), calibration level A, revision level A
Transmission, Part Number - E3SP FA = automatic transmission (P) originally engineered for 1983 (E3) Thunderbird (S), revision level FA
Seats, Type - 2 = low back front buckets
Belts, Color - H = Desert Tan
Line D
Groups, Promot/Decor/Appear/Protection - [blank] = no promotion, decor, appearance, or protection groups
Wipers - [blank] = no interval windshield wipers
Defroster - E = rear electric window defroster
Clock - [blank] = no clock
Radio - S = AM/FM stereo
Spkrs - 4 = four speakers without premium sound system
Antenna - A = automatic antenna
Lights, Headlamps - [blank] = no auto headlamp system
Lights, Entry Dimmer - [blank] = no light entry dimmer system
Lights, Light Group - [blank] = no light/convenience group
Power Aids, Decklid Release - [blank] = no remote decklid release
Power Aids, Locks - [blank] = no power door locks
Power Aids, Windows - M
Glass, Tint - T = tinted glass
Mouldings, Door Edge - [blank] = no door edge guards
Mouldings, Rocker - R = rocker panel mouldings
Air Dam - [blank] = no foglamp airdam
Road Abrasion - [blank] = no road abrasion coating
Luggage Rack - [blank] = no luggage rack
Mirror, Vanity - [blank] = no vanity mirror
Line E
Battery - DC = heavy duty battery
Rear Axle, Tag Number - 462A
Front Springs = DYT = front springs (2nd & 3rd "TR" codes on door tag)
Rear Springs = JAD = rear springs (4th & 5th "TR" codes on door tag)
Front Stabilizer Bar - V0
Rear Stabilizer Bar - G
Line F
Wheel Cover - 5
Wheels - VG
Tires, Size - 1957514 = P195/75R14 tires
Tires, Color - W = white sidewall tires
Speed Control - S = fingertip speed control (cruise control)
Cover/Pad & Type Wheel - 8S
Wheel Color - H = Desert Tan
Type of Col - T = tilt steering column
Hood Scoop - [blank] = no hood scoop
Frt License Plate Bracket - X = front license plate bracket
Line G
Accent Stripe, Type/Color - BC
Bumper Guards - E
Fuel, No Lead - N = no leaded fuel
VIN - 1MEBF9 = [decoded above]
Build Sheets
Sweet. I would say that's dead on with the exception of the clock and antenna. It had just the standard, non-power antenna. And it had an buttstuffog clock.
This post was from 5 years ago though, and that poor cougar is in fox-body heaven now. I sold it to a guy for $400. He said he wanted to fix it up with his son. Turns out, he was a liar. He drove it home, packed his belongings into the car and left his family, and junked the car to get his $400 back. It was a free u-haul I guess.
Build Sheets
Quote from: CoogarXR;450516
Well I dunno for sure but could be a std item(meaning not optional or a upgrade wasn't ordered) would not have a mark in box, as all would get the std version unless the build sheet stated differently... I'm 99% at least on the antenna...
