Topic: Che feedback (Read 7649 times) previous topic - next topic
Che feedback
I've got 275-40-17's out back with no rubbing.
Che feedback
Quote from: bigbada1;344347
I have the upper and lowers adjustables along with mach springs and strange 10way adjustables the lowers are cranked up almost as far as they will go and I am hitting the fender wells with my tires when I go threw a dip. I really do like both the uppers and lowers I just need to either run a smaller rear tire or have my fender lips rolled.
What setting do you have the shocks set at?  If I did the math correctly, that works out to a 26 1/4" tall tire.
Che feedback
I've got 275-40-17's on the vert....I had rubbing in the back....I put air shocks in and raised the back up. it only rubbed when I hit potholes.. Unfortunately, most of NY is pothole... The car has a Lincoln rearend in it, and pushes the wheels out a bit further then they should. The very outer edge of my tires catch the wheel well. If the rear was from a Cougar or Bird it probably wouldn't rub...
after the air shocks
this is how it sat before.
Che feedback
I'm running the CHE non-adjustables with Moog 8599 springs and Bilstein shocks for a fox Mustang with the shock mount relocation brackets from Chuck.  My tires in back are 255/60-15's --- a 27" tall tire.  I've yet to come close to rubbing.....
BTW Jerry that pic you posted with the reborn Cougar in the background is pretty much where mine is at right now.
Che feedback
Same size rear tires as you Paul....I haven't driven the car, but just by looking at the tires, and wheelwell, the tire is well inside of the lip, and I'm pretty sure it's not going to even come close to rubbing.. I believe I used stock springs in the rear, and the non adjustable CHEs. I'll use adjustable shocks to fix the height problem I'm experiencing in the back.
Che feedback
Actually I'm running 255's,besides no where near rubbing, Like Paul said maybe your shocks are set to soft.
Che feedback
Che feedback
Shocks are cranked up to 8 and they rub how many of you are running Mach springs???
87 TC
Che feedback
I'm using Sn-95 Mustang springs (stock GT springs). I still have plenty of room inboard and outboard of the tires (as I said,that's with 275's),but I did have to toss the ol' quad shocks into the "for sale" side of the garage. Long gone now.
Che feedback
For reference purposes......
I miss my car  =(
Che feedback
Quote from: vinnietbird;347567
Think you tossed those my way...... (If you ever wonder why you can't find them again)
Che feedback
Quote from: V8Demon;347574
I miss my car  =(
You know.....The front of yours isn't much lower then mine right now.....I still have hope after everything gets bolted back in.
Che feedback
Humm now Im wondering if my tire offset isnt wrong because looking at things I think that if there were no tire bulge at all I would only clear the wheels by about 1/4 inch at the fender lip. Im going to measure backspacing tommorow.
87 TC
Che feedback
Can you post a couple of pics?
Che feedback
Quote from: daminc;347578
Keep in mind I have no A/C and aluminum heads..... The front end on my car is about 150 pounds lighter than when it left the factory.  With the stock springs it sat much higher than it does now and as shown in the pic.  The current springs up front are Moog part #8598.  Before I redid the suspension it was starting to get the old gasser look as the rears were starting to sag.
