Topic: Show your engine now !!!!! (Read 214431 times) previous topic - next topic
Reply #120
The intake is cast in a mold,and the "sand" used in molding has to come out somewhere,and those holes aid in the molding. They have to be sealed,so,freeze plugs.
Reply #121
Quote from: sarjxxx;345482
why do all SEFI v8 intakes have what looks like freeze plugs in the sides?
Both your 3.8 upper manifolds have the same thing. My 95 does.
Reply #122
hmm yeah but mine doesn't look like a freeze plug...its a plastic cap that matches the shape of the contours there
Reply #123
The plastic cap probably covers the plug. My Sport had a cover as well. Most times,they fall off as the adhesive gets old.
Reply #124
no it snaps in
Reply #125
Motor I put in my sons 88 sport....
Explorer motor with GT40 heads, FMS 1.6 roller rockers, 65mm TB, MAC headers, X-pipe, 05 GT lers.
88 T-Bird Sport-- H.O conversion, GT40 heads, FMS 1.6 RR's, Cobra/EXP intake, 65mm TB, MAC headers, X-pipe, 05GT lers, TC 8.8 with 3.73's.
Reply #126
Nice. I like that you painted it Ford blue. Are you still running the stock Explorer cam or did you stick in a HO cam?
Reply #127
Quote from: thunderjet302;345631
Nice. Are you still running the stock Explorer cam or did you stick in a HO cam?
Kept explorer cam in it..  Works fine, car isnt raced any plus wasnt looking for all power. And figured it would work good with the 3.73's rear end I putting in car,since the explorers ran that combo.
Reply #128
Quote from: JD8850;345633
i like the ford blue lower intake paint as well.. very nice
Reply #129
.................with the GT-40................
Reply #130
I have a different upper and lower intake and intake tube now and soon to be distributorless.
Reply #131
Quote from: vinnietbird;347597
Now that looks good Vin!!!!!
Reply #132
Quote from: andrew beedle;348138
Thats pretty sick man.  I love how it still has AC.  Did you do all that work yourself?
Reply #133
I'm still the red headed stepchild here. :mullet:
1987 TC
Reply #134
i have a different upper and lower intake and intake tube now and soon to be distributorless.
wow!!!
