Topic: drain holes for tbird door (Read 1261 times) previous topic - next topic
I was reading a thread yesterday (dont remember who) but they were discussing clogged drain holes in the bottom of the door starting rust because of the bad dew wipe.
I was curious where these holes were, I'm not seeing them on this new door I just bought. Should I drill/ re/open them or is there a better spot to have them at?
I am por-15-ing the inside of my door after I rough it up in there, I just want to be double 200% sure this door will outlast me.
1988 T-Bird LX- Awaiting HO build, Monster "Eat My Shift" AOD rated 550Hp. BBK ceramic shorties, Jegs mustang (catless) H-Pipe. mustang catback modified axle back for tbird, 94 17" Cobra wheels, 98 'Stang GT 8.8 Traction-lock
There should be 3 or 4 or 5 slots, maybe an inch or a little longer in a row...the may be under the weatherstrip, it's been awhile since I looked, so not 100% sure...
I'm sure Jerry or Eric could probably be of better help in regards to drilling new holes if you don't have them though.
Oh, i was looking for little holes, and did not check under the strip. When I get off work ill have to pull the seal.
If you want I can take pic of the underside of my doors. They look just like they rolled off the assembly line. California is great for cars :)
here's more
And what happens when they clog....
That's ugly!
I suppose we should also keep an eye on the window weatherstrip to prevent junk from getting in the door in the first place.
1990 Mark VII LSC
1990 Mark VII LSC SE
1969 Cougar 351W
