Topic: how do you adjust toe-in? (Read 3145 times) previous topic - next topic
cool i'll try it
...Sarjxxx. Remove the boot from the steering rack, and you'll see the flats that you're supposed to use to turn the inner tie rod. You loosen the Jamnut for the outer tie rod(Green arrow) then turn the inner rod by the rack. You shouldn't need to hold the large nut that attaches to the steering rack while doing this, but it can't hurt.
Also be aware that if the boot isn't secured back in place well enough, you may get a slow drip of ATF if your rack isn't in the best shape.
i thought his question was fox related because i was going to suggest checking the strut top thingy and see if it moved. my ps wheel was visibly toe out and the cause was the strut top lossened up and shifted(visble by the sed paint and sheered off pin). 2 minutes and a big ratchet fixed that up.
it wore my tire out pretty fast like that.
it was a fox question. we just got a little off topic lol
thx, I don't think my strut's out of line but I'll check tomorrow.
Quote from: 20thanniver-ls;343835
It is easier to replace the control arms than to have  the balljoints pressed out, then have new ones pressed back in. Oh, and a word of advice on parts, Moog and Motorcraft are the only way to
The ball-joints on the MN-12 aren't like the Fox cars. They can't be removed and pressed back in. They're physically part of the upper (and lower) control arm. Super Coupe Performance is where I got mine from. Bill sells good shiznit, y0
Quote from: sarjxxx;343847
I gotta go over my whole front end on that car at some point anyway. I think sometime (probably late) next year after money picks back up and the cougar is up and running I'm gonna start attacking the suspension on the bird.
I got this weird pop in my front end when I accelerate too hard and the front end lurches up and then pop again when it comes back down and sometimes during hard bumps or potholes too. I'm not sure whats doing it... I tried to figure it out before but I couldn't isolate it. I'm sure its not good whatever it is.
Not to burst your bubble, but the popping is probably the upper ball joint.
You should figure it'll be about 150$ for the upper control arms & another 150$ for the lower control arms. So, I would do the UCA's then go to the LCA's. They're a piece of cake to change. My wife's older boy & I tackled them in the better part of 8 hours.
You'll need an 18mm wrench ...although I recall using a 19mm somewhere on the upper. I'll see if I can find the pics from when I did mine.
Quote from: Scott D;343982
They most certainly can be pressed out, and you can buy just the balljoints separate from the UCA. I don't recommend doing it this way, but it can be done. Do a search on Tccoa  - plenty of people have done it that way.
FOXLESS!!
1994 Lincoln Mark VIII
Quote from: jrad235;343864
...Sarjxxx. Remove the boot from the steering rack, and you'll see the flats that you're supposed to use to turn the inner tie rod. .
 x2,, thats what the flat areas are for.
