Topic: Smog pump delete belt length? (Read 2147 times) previous topic - next topic
Could someone tell me the smog pump delete belt length with stock pulleys. Or possibly show some pics . I bought an 84.5 belt but can't seem to get it on.
What engine and what year?
88  5.0l
I checked on some stang sites . and they suggest an 84.5 in belt . I can't fit it on .
Just cut an old belt or use a string and wrap it around your path and compensate for the tensioner.. You really don't need anyone to tell you the size, measure it!
Thats all i did. Just did the string  length measurement and bought a couple belts. Then returned what I did not use.
:burnout:
There is also two different ways you can wrap the belt.
I got the right one after 2 try's . 87 5/8 in .
Your power steering pump bracket and A/C brackets are totally different from those on a Fox Mustang; hence the need for a longer belt....
When I did the 5.8L swap I used mustang serp setup. Which is now wider.
:burnout:
your tension pully can also be modified by cutting away some of the aluminum housing at the "STOP" point so you can actually install a much wider range of belts.
thats what I did,,
