Topic: Door Locks locking by themselves-Problem Solved (Read 4062 times) previous topic - next topic
dood,, ,,,,nevermind.
first off, unhook and disable this remote system and put things back to factory.
Im betting its your aftermarket remote.
tell me the frequency its on isnt gonna be effected by other random radio waves jumpin around in the air.
how about this,,, drive out the country and see if the problem persists,, if not then you just found your problem.
If swapping the relays causes the problem to change from locking to unlocking or vis versa, then one of the relays is bad.
Alright, well I've been screwing with this all morning. I found the remote start/door lock unit that Rayco car electronics installed, I unplugged every wire running to it, the problem persisted.
I took the door panels off and unplugged both of the door lock/unlock buttons, the problem persists
I fished around inside the doors and unplugged both actuators, one at a time, the problem persists just with whatever door isn't unplugged. The drivers door makes a different noise than the passenger door, the drivers door unlocks itself, but it makes another electrical sound.
I keep unplugging one of the relays from underneath the passenger seat to stop the door from continuously trying to unlock. I'm out of ideas now, I now know the switches are not stuck, but what else can cause this? Is there a central brain for the locks? Where is it? Anyone know what could be causing this now?
Well I found the problem. While riveting the patch panels in the floor a couple of weeks ago one of the rivets, or the pilot hole drill must have tapped some of the wires on the drivers side next to the kick panel. Two pink wires and a white with black stripe wire to be precise. Well the must have been in contact with each other, and the plastic coated was chewed away and this cause the doors to keep unlocking by themselves. I cut the bad section out and soldered them back together, retaped the harness back together and when plugging the relays back in...... Silence! No locks unlocking.
So problem solved, I thank everyone for chiming in, another problem solved, another victory for Foxtbirdcougarforums!
good thing,, had my eye on this one wondering if you really would find a live breathing grimlin.  thats about all that was remaining that could have caused this.
Quote from: jcassity;346288
Thats for sure. And just my luck too, it's always the last possible one that ends up being the right one.
Quote from: jpc647;346300
Hey I suggested checking the wiring on the first page.... wasn't exactly last possible thing....LOL Glad you got it figured out. It drove me nuts when I had this problem with my Mark. It even killed my battery overnight.
FOXLESS!!
1994 Lincoln Mark VIII
Quote from: 20thanniver-ls;346448
I read about the grounding suggestion behind the door panel, which I checked when I took the door panels off. This was in the wires at the kick panel. But just the same. My battery was dying overnight too.
While it was happening on mine I was at the shop getting new tires freaked the dude out a little, the shop dude thought I was insane for putting new tires on a "busted 'ol car"
FOXLESS!!
Quote from: 20thanniver-ls;346474
Yeah, I get that too. But I keep thinking that even though this busted ol' car isn't the prettiest, it isn't the fastest, and it got more problems than I can shake a stick at, I'll just keep plugging away at them, with the help of you guys, and I keep thinking about that $400 a month car payment I don't have. I figure if I buy another car, it should be new. With a warranty and all that, and until I can do it in cold hard cash, I won't.
