Topic: sn-95 inner and outter tie rods different length than fox? (Read 1436 times) previous topic - next topic
I mocked the rack up on my new autox car 87 bird - 04 mustang spindles, tc rack, stock arms with 04 mustang ball joints, stock kmember.  Anyways I got it all put together, but it has MAJOR toe in that I don't think there will be enough adjustment in the factory tie rods to dial out the toe in.  right now if the angle of the two sides were to come together, it'd be 45-60* between the two!  If the sn95 tie rod stuff is longer, I will just get that stuff.
with my t-bird lower control arms and a stang rack(91) and mustang-t-bird tie-rod ends. I had to adjust them way out(like only 1/2 inch of thread in tie-rod. But by putting a mustang lca on. It moved everything in 1" or so. Helping my track width problem and tie-rods work like original!!! But i have 91 ho stang control arms and spindles!!! Prob not much help to ya but i do believe sn-95 rods are different and must be used with spindle swap,and the 96-98 stuff is 10mm wider. 99-04 pbr stuff i dunno!!!
1999 Trailblazer(wifes rig)
