Topic: Red lens Tripminder for sale (Read 2377 times) previous topic - next topic
I  need one. Mine went to doing some wild flashing when I started the car,then after a minute or so,it stopped flashing and I reset it. I'll see what I can do to come up with come funds. Mine are gone til I can sell some more parts.
Do you still have that nice stock stereo?
I do.....wanna trade?
That's what I was thinking.
I'm good with that. I can box it up and probably ship it to you Monday after work......if that's fair to you.
Yeah, that's fine by me. Do you know if the tape player works?
It worked great when it was pulled. Bill (the yard owner) ran jumper cables to the car and we were testing everything before we started tearing into for my dash and other pieces. Otherwise,it would stay with the car.
Awesome.  Do you need me to put mounting brackets on the tripminder or are you planning on reusing yours?
Either way. If I do it,what is your method? I've never dealt with them as far as swapping brackets. Also,PM me your address info.
Is your unit originally from a fox car?
Yes it is.....I'm assuming. The brackets are for my car,and they seemed to be riveted on I believe.Or fastened something similar.
Yes Vinnie I pulled it from an 84 Elan
Yeah, sounds like a fox unit.  They come riveted on stock.  I attach the brackets with epoxy.  Personally, I would prefer the riveted on brackets to epoxied on ones.  I haven't had any epoxied ones come loose, but the riveted seems like it would be better.  If I were you, I would take apart both tripminders and use your case w/brackets and the insides of the one I have.  If you don't feel like messing with it, you can send it along with the radio and I can do it.
The one I have in there now was a "reman" unit I believe. The other one I traded some time ago thinking I didn't need two of them. Well,maybe I was wrong. I had them side by side in a box when I did the dash swap. Grabbed one and installed it. When I realized which one I had installed,I decided to leave it in.
ok then :P
