Topic: TC steering wheel ,cool parts,and more..... (Read 3293 times) previous topic - next topic
Parts need a home...buy them.
Roller rockers are here and ready for new home under someone's valve covers
What kind of shape is the AOD shifter panel? any broken tabs?
Quote from: flipnbird;341811
I'll try to have a pic for you after work.
Updated list folks.
OK.,no pics,sorry about that.BUT,it's missing one of the plastic tabs that snaps into the console.The other is well and intact. Other than the one missing tab,it's in excellent shape.
Thanks, but the one i have now is just missing one tab also, if you can find one with no broken tabs in excellent shape give me a haular!
Will do.
Rockers are sold.
I've been neglecting coming here as I'm tires of the login issues - if I login, I have to then go to a subforum and then come back to the main screen in order for it to give me the complete forum list. Simply refreshing after logging it will kill the credentials.
I haven't gotten a picture yet as it has been pouring all week when I've been in the car, since I said I would take it. The dark skies (first storm of the season) make it impossible to get an in-focus picture. Don't want to dig out the SLR.
Enough of my excuses - I'll try to get it today :p Looking at it this week though, it's quite marbled with faded "gray" on the top/top left sides, including the front but the texture is still there (although less than the other side). Perhaps I SHOULD use the SLR as the flash might help bring out the imperfections quite a bit.
1988 Thunderbird Sport
I'll try to get a better one of mine later this evening.
A couple of new items listed.Stuff needs to go. Buy it up. I'll do my best to work with you. The Sport needs funds,so,parts have to find a new place to live.
Vinnie, will the NOS power antenna work for an 83? Mine still works just thinking for a spare. Also any luck with the block off plates for the t/c hood scoops?
Do you have pictures of the antenna unit?
Yes......yes I do..........
Anybody going to be needing roller rockers???
