Topic: firing up ho with so computer (Read 3240 times) previous topic - next topic
Quote from: ThunderbirdSport302;340868
That won't matter very much in his case, if at all...the fuel/air isn't going anywhere until the intake valves open...he'll have more issues with idling than anything. A lot of things to consider, for example; is the car forced induction? does it need a mass-air eec? etc etc.
I've got an '86 5.0HO eec, I'll send it to you try in there, if you want..up to you..
not sure if or when the Stangs went to sequential, but I do know the trucks were batch fire throughout most of the 90's.
The other ford cars I don't know about, so I can't say.
Quote from: Bruce M;341383
The SO computer fires the injecters by bank so the firing order on the injecters dont matter. So it will run fine for brake-in. The HO fires the injecters sequential so it will only work with the matching cam firing order.
All passenger car 5.0s both SO and HO are SEFI. Only the trucks had batch fire.
Quote from: thunderjet302;341420
That makes since. The only thing I put a HO in was a 86 Bronco. And it ran fine with the stock truck computer. Does'nt the trucks run 19lb injecters? My truck had yellow top injecters.
