Topic: Running hot (Read 1996 times) previous topic - next topic
Running hot
Well, my drivability issues are solved. I replaced the tank and the sending unit, all is good. Starts much easier, no more bucking.
But, now I'm running hot! The car got up to 210 just around the block. I replaced both radiator hoses and the water pump. The car ran fine before. Also, it's idling high, as if it were cold. Do these symptoms sound like a thermostat? Or maybe just an air pocket in the cooling system? And was that long spring in the lower hose important...? I didn't put it in the new one.
Thanks, you guys have been a ton of help. :bowdown:
*edit* Oh yeah, one more thing. While the car was at 210, the overflow bottle didn't fill up. It stayed around the cold fill line.
2002 Honda Civic EX
1984 Ford Thunderbird Elan
5.0 CFI, T5, Dual Exhaust
Running hot
It may be a good idea to replace the thermostat anyway, especially if it hasn't been replaced in a while,  and if it is not opening up your car will overheat.
FOXLESS!!
1994 Lincoln Mark VIII
Running hot
I wish I heard that before I put the water pump on :p
2002 Honda Civic EX
Running hot
How long has it been since you last changed the thermostat/coolant and what temp do you normally run at?
FOXLESS!!
Running hot
Before I did all this work, it rarely ever got over 180. That was a few months ago. And I assume that the thermostat is the original 26 year old, 140K mile thermostat.
2002 Honda Civic EX
Running hot
If that is the case, replace it, and see what happens.
FOXLESS!!
Running hot
The spring in the lower hose is important too , it keeps the hose from collapsing at higher rpms
Running hot
Alright, will do. Thermostats are cheap, 5-10 bucks, and I'll throw that spring back in the hose.
2002 Honda Civic EX
Running hot
just wondering.. is it a 5.0 and are you running a serpentine or V-belt?
Running hot
Yes, 5.0. It has 3 belts, one V belt for the waterpump and power steering, one belt for the alternator and air pump (not hooked up), and one for the AC and an idler (belt isn't even on, winter time+no freeon=why bother?)
2002 Honda Civic EX
Running hot
are you sure you have the right water pump? Vbelt and serpentine belt pumps rotate in different directions
Running hot
Boy, that would be......not good to say the least! I got the pump from Advance Auto, I can only assume it's the correct one.
2002 Honda Civic EX
Running hot
check the part number.. it wouldn't be the first time the retards at advance screwed up lol
Running hot
Quote from: turbo_88_XR7;337866
I'm not too sure how I'd go about doing that...the pump is on the car and the box is in the trash. The receipt says I received this pump
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_New-Water-Pump-GMB_5420156-P_54_R|GRPCOOLAMS_1391295481___
Which appears to be the correct one.
2002 Honda Civic EX
Running hot
hmm.. seems to be the right pump.. my guess is thermostat or air bubble.. try squeezing the upper rad hose with the rad cap on to try sucking any bubbles into the radiator, then just top it off. you definitely need the spring though, like stated above.. the hose will collapse under high RPMs
