Topic: Look what my stupid ass did (graphic pics) (Read 2874 times) previous topic - next topic
Only stitches I've ever had none of you will ever have to deal with...
As for broken bones I've broken all of my fingers (most multiple times), a few toes, a couple ribs, my nose twice and my leg. I am a certified klutz! Though I've never had a cast (cuz I don't go to the dr soon enough...)
Good luck on the healing. I'm very bad at limiting my mobility for anything. They told me I couldn't go in the body shop at school on crutches when I broke my leg, I threw em in my car and said what crutches. Since you're worried about missing sports sounds like you're the same way. Try and take it easy as long as possible and here's to a quick recovery!
Quote from: crystal;337867
sounds about like what I did in auto repair class. they wanted me to sit out and I told them no and walked on it anyways. I wasnt going to miss out on working on a 57 belair
Quote from: 88turbo;337868
Don't blame you. I'm not a Chevy fan but I worked on a resto of a 55 Chevy at a shop in Ohio and it's one of my fav builds so far!
Ouch!
well, thats a really good one you got there.  I hope it heals good and you dont get infected.
do what i do,, you probably have a hole at the end of the handle for a reason,, slip you a rope through there and tie it off but...make the loop big enough so you can slip  your hand through the rope and grip the handle.
Its a built in safety.
Ive got my hatchets done up the same way.
I use mine (i call it a corn knife) to help me out on the car when i need to have pedals worked in the car.
The see the rope?
sometimes I use the corn knife to help bleed brakes.  I pump up the pedal, then put the corn knife in a bind between the steering wheel and the brake pedal which puts it in a really hard bind and bow.  I then just loosen the bleeder and the pedal goes all the way to the floor.
anyway,, get you a rope on that handle,, gotta learn from this mistake.
is that mule tape on the handle?
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Be glad that it wasn't a few inches higher and to the middle. Sorry for the pain,though.Now you have time to sit and think about future projects.....and have the wife wait on you hand and foot (if you're lucky).
not much help from the wife 7-1/2 months pregnant
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Mmmm... Tasty.
I havent had stitches in a while. Not saying I shouldnt have, I just try to avoid the ER. Hate waiting around in a smelly place with a bunch of whining people.
for some reason I have a strange craving for a burger now....  ;)
Not for the Faint for sure!!! U should post graphic nature warning!!!!! LOL!!  Get Well!!
1999 Trailblazer(wifes rig)
another with my  inside lol
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
 that is nasty.  Glad you are OK.  Next time you need one of these...
That's what I use for a corn knife in my backyard...lol.:hick:
SEWD up nicely!!!
