Topic: fog lights wont work (Read 5111 times) previous topic - next topic
last night I finished the engine swap in my 88 TC and also change the fog lights, the right side worked and the left side didnt so I looked further into why it wasnt working.  well what I found was the ground terminal was rusty so I changed the end and the lights started to flicker and then they both starrted to flicker and inside the car there was a clicking sound then they stopped working. I checked all of the fuses and didnt find any bad ones.  anyone have any ideas?  thanks Graham
Re: fog lights wont work
possible that the headlight switch or the foglight switch took a dump
Um, i know kind of off topic, but did you swap in a 5.0?
id like to see it!  :D
1985.5 SVO
If i remeber there is a relay for the fog lights. With  All the clicking sound that you said you heard I'd say that is you problem. Eveytime I 've had a relay make that kind of sound it went out then or soon after.
that's also what I have been thinking, wich relay is it? and can I swap them around to see if that is the problem? thanks
theres no relay, power goes directly through the switches
yes there is a relay look at the pic of the wireing diagram
Not on 1987-88 Turbo Coupes...they're routed directly through the switch. Same thing with 1987-93 Mustang GT's. Both are notorious for frying switches and intermittent fog light problems. For the TC there is an excellent article here on how to solve the problem:
http://www.turbotbird.com/techinfo/installing_headlight_relays.htm
yeap
so my problem is the switch huh..  no relay at all in my 88?  I would really like to get them working again.  Graham
follow-up:  tested the foglight wiring that goes to the switch with a test light and I got no voltage with the headlight switch in the on position with the low beams on.  any other ideas?
you try replacing the headlight switch?
