Topic: H.O. swap about to commence (Read 15599 times) previous topic - next topic
Reply #45
What converter are you talking about?
Reply #46
torque converter.
Reply #47
Quote from: daminc;339452
torque converter.
Lol.
I would replace your transmission input shaft seal or at least inspect it carefully.  Can be done pretty easy.  Sucks to do all that work and have a leaky trans when your done.
Reply #48
Quote from: hypostang;339418
Just out of curiosity , why did you remove the engine with the converter attached ?
Yep bad move, if the engine didn't pull straight out, the hub on the converter likely damaged the front bushing in the transmission...
Reply #49
I wasn't aware that you could detach the torque converter from the fly wheel without removeing the engine first. How would you reach the bolts?
Reply #50
You remove the lower inspection plate and remove the nuts , you do have turn the engine over to get to all the all of them though.
 It is a tight fit getting a wrench in there .
Reply #51
I hope you don't try putting it back in the opposite the way you took it out!, I think your goin to learn something?. Any chance you looked at a manual?, You caused more headaches for your self than you needed to do. You will learn. Your pics are good, Take some more on the redo. Ask some one, There's help here someone will  guide you the right way.
Reply #52
O.K. this is where our lack of experience with automatic transmissions starts showing it's ugly nose. But this is also where having you guys to help out is a great resource.
Reply #53
I do have to ask,why is the engine being pulled? also where in the states do you live?
Reply #54
Swapping out the old S.O. engine for a H.O. engine. I live in North Carolina.
Reply #55
What part of NC?  I'm near Charlotte and would love to come see the swap!
Reply #56
Asheboro.
Reply #57
Yeah, if you know where you can get another good AOD for cheap, I'd be grabbing it. Would've also avoided all the ATF everywhere by leaving the t/c.
I ruined a trans at the junkyard, I was separating a 3.0 and trans from a Taurus, took the fast, easy way, pulled the trans off and left the convertor...the boss wasn't happy. Neither was I, after the customer brought the car back that I swapped that same trans into...with a kick-ass front seal leak. The labor to replace said trans was free....meaning I didn't get paid to fix my f*ckup. :hick:
After that, I spent the extra 10 minutes and took out the 4 bolts, and left the converter on the input, lol
I'm not bustin' your balls, I've been there. Hopefully, you got lucky. :bowdown:
When you take the bolts out (or tighten them per reassembly) use a pry bar, wedged in the ring gear teeth to keep the flywheel (and engine) from turning as you tighten/loosen the bolts. You'll have to use a wrench, and there's not a lot of room, but it's the best way unless you love replacing your AOD. That, and you'll never get the converter seated correctly to drive the pump if you stab it all back in there opposite of how you pulled it. ;)
Reply #58
Got a little work done today. We ran into a snag with one of the torque converter nuts was almost stripped off. Had to take a chisel to it to get it off. I removed most of the brackets from the old engine so now I've got to get them cleaned up to go back on the new engine. We got the new engine on the engine stand and got the headers attached.
Reply #59
You're getting there......one piece at a time.That's how I did it.I mounted the short block on the stand and started building on it until I finally had a quality engine,that also looked pretty sweet.Keep it up. I went a completely different look,but,I have always liked the factory Ford gray.Odd but true.
