Topic: Retaining Factory Amp (Read 5203 times) previous topic - next topic
In the trunk , at the amp .
Ah I see.... And that would make the factory amp pretty much obsloete and I wouldn't have to worry about the red wire that was hooked up to the back of  the stock radio (which I found out was the ground for the factory amp)
FOXLESS!!
1994 Lincoln Mark VIII
I justtook a look in my trunk and although I couldn't tell what my factory amp looked like, it dosen't look like the JBL in the link you posted
FOXLESS!!
Well that will not work then , dang
Yea, that sucks. I may just run new wiring to all the speakers and only use the stock harness for power, seems like  that may be the way to go
FOXLESS!!
I'm afraid you may be correct , that seems to be how most people have worked around the common ground system
