Topic: Overheating the Sport..... (Read 7365 times) previous topic - next topic
I can't answer that unless I just made up an answer.It's a compressor I had for some time waiting for this day. It's like the factory unit,but newer.I believe it was a reman. unit.I really can't remember when or where I got it.I do know it was still wrapped and packaged for about two years until I opened it about a month or so ago.
My '88 3.8 came stock with an Hr-980. I'm guessing that's what yours came with too, but idk for certain...
Not to be negative (it's great having A/C, especially here in Fl) but I've heard those HR-980 compressors don't handle R134 that well. I can't name the source of this info though because I was in the process of replacing my compressor a couple of years ago, so I just don't remember. Some guy from a dealership in Ft Lauderdale ended up mailing my mechanic one and we recharged it with the old R-12.
-'88 Tbird 3.8
-2012 Altima 2.5 BASE.
Future: Budget 5.0 300 HP.
Air Conditioning
Did you have your compressor replaced when the conversion was done or are you still running your original?
Stroked and Blown
[SIGPIC]
Quote from: RunninWild;336331
V8s didnt use the HR980s :D
this is a HR980
http://cgi.ebay.com/ebaymotors/88-87-83-Ford-Mustang-SVO-A-C-Compressor-HR980-NEW_W0QQcmdZViewItemQQitemZ270447282538QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Everything original to the car is looooooong gone.Everything but the condenser and harness for the a/c was replaced. As I said,two of the three lines were custom built to fit my engine bay (strut tower brace,etc.),one with the dryer was brand new (I got it brand new for $9.00 on a lucky ebay score a year or two ago),new Good Year belt,replacement a/c bracket,steering pump and compressor.  I can't ask for any more than they (Olde and New) did for the Sport.Very good work,and they stand behind their work.They have been around here for 17 years,and do no advertising.All word of mouth. Really great guys,and very honest.I dig that a lot.
Mine is like this one....not from these people though....
http://cgi.ebay.com/ebaymotors/A-C-COMPRESSOR-93-MUSTANG-/320580483762?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AMustang&hash=item4aa415fab2
Im glad they hooked you up Vinnie , I could not imagine not having A/C
Quote from: hypostang;336335
Then what I said is null....:toilet:
I thought they might have used the same ones. I know they used the HR-980 on the the TC's and SVO's.
Why didn't the V-8 get them?
-'88 Tbird 3.8
I have NO idea.Perhaps it's how they mount up.I'd need to see a pic of the HR-980 to see the difference.
Reply #39
Go back up a couple of posts ;)
Reply #40
Quote from: hypostang;336344
Thanks....No way would that bolt up to the 5.0 bracket.
Reply #41
Quote from: vinnietbird;336320
It's the 134R stuff.
But there is no cutoff switch that'll just install that is factory calibrated for the r134's lower running pressures. The system's likely cutting off at like 35 degrees at the evaporator instead of the more optimal 25-27 degrees (this will cause the beginnings of ice formation on the accumulator). In the car, this made a huge difference for me. You won't be able to adjust it without a pressure switch though (and potentially some way to reclaim some of the r134 if it's in excess) so eh, if you're happy, so be it ;)
1988 Thunderbird Sport
Reply #42
That's what my factory compressor looks like.
Reply #43
Quote from: Seek;336348
 Yes there is,  a  cut off switch from a R134 equipped crown Vic or F series is a direct swap  :D
Reply #44
I actually think the switch (if it's the one on the dryer/accumulator) did come from a Crown Vic cop car....yellow on the bottom.I really didn't look to see if he used it or replaced it.
