Topic: Turbo Coupe exhaust. What exhausts are best? (Read 2826 times) previous topic - next topic
Im gettin ready to do the exhaust on my 88 turbo coupe and i am wonderin what everyone is doin.  i want to ditch my converter for starters and i know i want dual's for sure.  Ive seen stingers exhaust systems for sale. Is anyone running that?
I have read alot of good things about Stingers exhaust, but I personaly have yet to try one.
...and there was light!
I run 2.5 back to a hooker aero chamber ler with a turn dom just before the rear
no matter what ler you go with , make sure its a blow thu and not a baffle style.
flow masters are a no no for turbo apps
I prefer a single 3", with a tail pipe.
I've got a Stinger tail pipe, but I needed to make a couple adjustments to it for my set-up, as well as add a tip to extend it to the bumper.
Quote from: BogusSVO;334917
can you tell me why? I run dual 40's with no ill affects
Quote from: 88turbo;334920
 simple, baffles rob you of HP, by causing back pressure, they slow the spool time of the turbo
Its a more than well known fact that baffled lers are the worst thing you can put on a turbo car. You might *think* you've seen no ill effects until you take them off or put good lers on.
Oh and flowmasters are usually the worst in flow tests.
Quote from: bhazard;334934
Ironic, huh?
One question, do 4 cylinder cars really benefit much from dual exhaust? It seems kinda unnecessary to separate the exhaust after the manifold. It makes sense to have dual exhaust on a V engine, but on an inline it seems like it wouldn't be improving much. A larger, single exhaust seems like it would be better.
2002 Honda Civic EX
1984 Ford Thunderbird Elan
5.0 CFI, T5, Dual Exhaust
you get more restriction  with duals than you do with a good single exhaust, more surface area that the exhaust has to pass over.
2 2inch exhaust pipes have more surface area on the inside than a single 3 inch would have
but the 87/88 tc came from the factory with it, it was split after the cat.
Quote from: BogusSVO;334939
cause it looked cool man:hick:
Quote from: sarjxxx;334944
Yeah looked so cool all tucked up and hidden...lol
so many choices . so many
My understanding is Stinger's single 3 inch pipe is the best flowing option, it is also cheaper and lighter than splitting it into the 2.5 duals.
i like the look of the LX 5.0 mustang exhaust tips, i want to copy that for my t bird .
