Topic: Help! I need a tranny and have ?'s (Read 5729 times) previous topic - next topic
I am needing a t-5 for my silver 88TC.  will a V8 tranny from a mustang work up to 95?  will a t-45 work? I have located several but I am unsure of the compatibility.
You're restricted to 83-93 v8 tranny's. The 94-95 used a longer input shaft, they can be used but you'll need to swap in an earlier V8 input shaft. They also used an electric speedo hookup that doesn't match the TC. The T-45 is a total no go. Uses a bellhousing that actually forms the front cover of the trans body.
You will need to have the pilot on the end of the V8 input shaft turned down to use it behind the 2.3.
A standard 4cyl. trans will work absolutely fine too.
V8 T5's came in two flavors. 3.35 or 2.95 first gear, with an overdrive ratio you may not like behind the 2.3, unless you like downshift for every small hill. In my opinion, for a daily driver, your best bet would be a 4cyl. unit.
BTW, PM on some details on the tranny's you find and don't want.
what Jangus said is correct, the piolt bearing nub is too big to fit behind a 2.3 with out some work
here is a chart on the T5 you will find helpfull
http://www.therangerstation.com/tech_library/T5ID.htm
the 2.3 NA mustang will bolt right in and work with out issues
unless you want to get the v-8 one and ill trade ya for it.
Got that fox rash again!
-Resident smartass! :ies:
Quote from: Cougar8775;334488
nice try buddy :D
The other option you have is to have your crank milled out to accept the V8 pilot bearing. If you did that to your crank you could then run either a V8 or and I4
T5 with the use of a V8 pilot bearing for running the V8-T5 or you would run a V8 pilot bearing with a brass shim for the I4-T5
87 TC
not having any luck :(  found 3 one guy wants $300-$350 for his and the other two wont answer or return my calls
Quote from: bigbada1;334531
couldnt the crank be drilled to accept the V8 pilot bearing?
well i do have the trans you despratly want.... And i need a v-8 trans for my swap.
Quote from: Cougar8775;334572
John, I have a C6 and a shortened D shaft if your interested. ;)
Graham,
    How soon are you needing one. I've got several, but I won't be passing by your area until Thanksgiving.
John
jerry id like to keep it 5 speed if at all possible. If i don't find the v-8 5 speed i need i can just find the different bell and clutch fork and let it ride( till it goes boom!). lol
Quote from: 88turbo;334536
I wouldn't try it myself (just drilling the crank) if it were drilled just a little off it would cause issues like lining up the input shaft not to mention if you did actually get the input shaft in and it was putting things in a bind. I was going to do this to my last 2.3 but ended up swapping in a 302 instead of rebuilding the 2.3
87 TC
I wouldn't try it myself (just drilling the crank) if it were drilled just a little off it would cause issues like lining up the input shaft not to mention if you did actually get the input shaft in and it was putting things in a bind. I was going to do this to my last 2.3 but ended up swapping in a 302 instead of rebuilding the 2.3 I would have a machine shop mill the crank if it were me
87 TC
I have bought a few parts from these guys before and they seem to be straight shooters
http://kansascity.craigslist.org/pts/1924357040.html
87 TC
