Topic: Is anyone's car not rust proofed? (Read 3054 times) previous topic - next topic
yep...Rusty Jones
Quote from: daminc;333793
Mine was rust proofed new, and garaged all it's life. Still trying to figure out what went wrong there. :punchballs:
one word: buffalo.
Ziebart hasn't stopped the rocker rot on the 95. Then again I think MN-12s came from the factory with rocker rot:hick:
Wasn't that the py recycled metal era
my red 86 was sure sealed, no rust on it but by the rear window. i wonder what it looks like now.
the other 86 wasnt rustproofed (from what i could tell) but nothing worth mentioning on it either.
what plugs are you guys talking about, the only plugs i remember seeing are body plugs.
anyone have a pic of them?
Sorry, all my plugs rusted off the car with the panels.
Quote from: daminc;333815
I think so. When ever I see a fox at the yard it will have rot but not near as bad as the MN-12s. The odd thing is most of the MN-12s are newer than the fox cars....
Quote from: thunderjet302;333827
Aren't ALL the MN-12's newer than the Fox cars?:poke:
John
Yeah good point:dunce:
I should have said from the 90s. Most Mn-12s are from the 90s, except for the 89s;)
No coating, no rust
Mike
I have no rust or coatings. And why I have no clue.
Dono about coating... I don't think I do, but I have found no rust anywhere on or under the car other than minor surface rust and a little in the windshield pillars.
One of the few good things about fl
I've heard that if you shoot rustproofing into doors and rockers, you plug the weep holes and it holds more water in the panels. No coating would mean that the moisture can escape easily, and air can circulate to dry it out. Kinda sounds like a good theory to me. Not sure if it's the reason though.
Underside of my car and the doors are good. Lots of small spots starting to rust on the roof and body panels though. Couple of our trouble spots I have avoided looking at... No rust proofing either.
Under side sure is bent up. Looks like someone took the car curb hopping.
-what is this "rust" you speak of???? :hick:
