Topic: Bad brake booster? (Read 5813 times) previous topic - next topic
Bad brake booster?
When you pull the front soft lines off see if they are swollen and closing the ID of the line.  If they are doing this then replace the one in the rear as well.
Darren
Bad brake booster?
Quote from: Aerocoupe;332780
Darren
They seemed fine when we pulled them, ID looked the same from end to end.
Just got done putting the last soft line on and bleeding them (ran through all four twice and bled out all the old fluid which was horrible BTW) and everything seems great. Stopping power is 100% better now.
FOXLESS!!
1994 Lincoln Mark VIII
