Topic: 4eye conversion on my 87 (Read 4680 times) previous topic - next topic
Quote from: jrad235;331928
That's because it's a Chevy!
j/k (Maybe)
The jury is still out for me, I was thinking about an H4(?) upgrade, but that link I posted  has projector lights that may fit. Might look a tich odd, but you never know.
haha! @ because it's a Chevy. Technically, you've got to show me love, because I've got a 4-eye ;)
Anyway, I'm definately interested to see how gumby's car looks when it's all done.
Quote from: Scott D;331929
'97 'underbird LX - One Gallon of American Fury! The ONLY 1997 Thunderbird on CoolCats.net
'89 Chebby C-1500 Silverado
'01 V-dub Jetta (the wife's mode of transportation)
....Where?! I see a Chevy though... :yuck:
Oh well, at least there is one Ford in your household.  :D
Quote from: jrad235;331935
Well, the Chevy's a four-eye, that's got to count for somethin' ...
Quote from: t3skidoo;331903
The pictures are good but it's still a little hard to tell exactly how close the fit is.  Is it higher in the center area than stock and/or more rounded on the outside, and/or concave vs convex on the inside?
yes, it is taller thru the center of the lamp than stock, and the face of the lens is more of a smooth curve than the straight front on the stock lights with the hard break around the corner.
here is a pic i omitted due to poor focus, but you can see a bit more  of the shape in the LS lens from the side angle
the top of the lens is laid back pretty hard. on the LS this part of the lens forms a continuance of the body line as well as the high crowned transition from the nose of the car into the hood.
http://www.avonmotors.net/images/pic2/1253594685-2001-Lincoln-LS-V-8.jpg
http://jkfmotors.tripod.com/images/2000_Lincoln_LS-2.JPG
this car has a vinyl application which accentuates that crown
http://www.mikekukielka.com/gallery/d/888-2/Lincoln_LS_racing.jpg
to work that shape flush into the header would actually lower the angle from hood to nose, changing the whole front aspect of the car. i think you would actually hafta raise the lamp higher in the header panel in order to form a smooth transition, at that point losing the hard body line in the header above the stock lamps and leaving a gap below the lamp that would hafta be filled.
my plan instead, is to try to tuck that top edge of the LS lens up into(behind? under?) the TC header panel, and set the light slightly back in the opening to mask the difference in curvature of the lens vs. header panel. kinda shadow box, or eyebrow type of thing. i dont wanna lose much of the flush look, so in my mind its a very shallow recess(1/4" - 3/8"). the lens on the LS light is obviously very clear which should help disguise the mismatch of shapes, i think.....
its hard to describe the picture in my mind. :sleep:
Quote from: gumby;331952
What if you took the clear covering off of the light, then formed lexan (or other impact resistant plastic) over the opening. Then the light would be flush with the header panel and it would give it the look of the recessed headlights the 83-86's have?
A bit of a frenched look.
Have you measured the LS hood to see how close it matches the T-bird's hood?  Heck, why not graft the whole hood, grille (fill the grille and add the TC bird emblem) and lights at the same time, and just install the turbo coupe scoops.  Then add a piece under the lights and grille to fill the gap between them and the profile line of the TC bumper cover.
1987 TC
After looking at the additional pics you posted, I was more or less thinking the same thing as as Scott D, remove the existing front lense, install the housing, form a new outer cover that retains the stock profile.
Another thought, maybe along the lines you mentioned.  While cruising evilbay one day, I saw a bare 87-88 header panel that got me to thinking about some kind of recessed lights for that nose.  The idea is to install cover ~0.5"-2" inset at the center, tapered to meet  the stock lines near the fender.  If reality can match what's in my head, it would give the bird a more aggressive look and still be aero.  (If that isn't clear, post a 3/4 shot of the bare header and I'll show you what I mean.)
__________________
Twin '85 TCs
White/ Grey 2-tone
Cut the fiberglass and build up the header panel to fit the light.
