Topic: Interchangeable Suspension parts. (Read 2620 times) previous topic - next topic
I just bought my roomates 93 Cougar. I'm gonna take the front hub assemblies and rear end out to do a 5 lug swap on my 84. The 93 has a 3.8L. Anyone know of anything I should grab for my Cougar that would be beneficial?
Quote from: cougrrr302;331739
Doesn't the 93 have IRS?
I'm not sure, but I don't think those parts are compatible with a Fox body. A 93 also has a different 5 lug bolt pattern than the normal Ford  pattern, it shares the pattern with the Taurus, Continental..etc.:D I also think the rear would be too wide, and requires a sub frame.
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Absolutely nothing in the suspension of that MN12 will work in your '84. They are two completely different vehicles, and the MN12 has more in common with a Taurus than it does with a Fox.
Correction: It's a 96.
I can't use axles or front hub assemblies at all then? Nothing from it will benefit my at all as far as 5 lug conversion goes? I paid nothing for the car. I'm gonna take what I want and crush it. This is why I'm asking.
Nothing at all will work. Completely different animal. The rear axles are independent (similar to the front axles in a FWD car, with CV boots et al), the front hubs and spindles are set up for an upper/lower control arm suspension with a coil-over-shock design. As Cougarman pointed out, even the wheel bolt pattern is different from normal Fords.
Well so much for that then. I guess I'll just part what I can off of it and crush it.
is the interior dash and door panels in good shape?
Remember, if the women dont find you handsome, they should at least find you handy.
When all else fails, get a bigger hammer.
Chris
 93 cat rebuilt 3.8
