Topic: New Clicking Sound from Engine Update! (Read 6863 times) previous topic - next topic
Reply #60
rotate your crank to zero deg in the normal running direction.
ignore the distributor completely,, screw it , it has nothing to do with the valves opening or closing.
remove number 1 spark plug
stuff a screwdriver in the hole and you'll find your piston is TDC (either on exhaust or compression stroke)
stuff a garden hose or something smaller in the spark plug hole
blow like hell in the hose.
if you can blow through the hose then rotate the crank one more revolution back around to zero again because you must be on exhaust stroke.
feel for your piston being on tdc once again.
If you can still blow through the hose then your timing is off by a tooth.
if you can not blow through the hose then shag it,, move on to the next thing on the list.
this is crazy and taking too long to diagnose.
theres no reason to be still wondering if your timing is off or not.
or
remove #1 plug
stuff the hole with barely damp paper towel
bump starter barely several times or cross the starter solenoid with a screwdriver intermittantly
eventually the paper towel will pop out
your TDC mark on the crank will have traveled too far past the pointer so rotate the crank the opposite direction going a little too far past the pointer
now rotate the crank to bring zero on your crank back to the pointer
now stuff a garden hose in the plug hole.
if you can blow air through, your timing is off by a tooth
if you can not blow air through then move on.
report back.
once upon a time i had an emission solenoid that was chattering when i was driving a certain speeds but i noticed it depended on the amount of pedal i was pushing ,,ie- the qty of vac being applied.  The solenoid was chattering and was directly related to the smog pump system.
Reply #61
Quote from: jpc647;345709
I think it's the intake. There is a small "slit" which looks like the gasket did not fill in correctly. I'll post a picture. What I'll do is when I get home I'll run the car, spray water directly there, and see if it bubbles, etc.
There is a slit between the outside of the gasket and the portion that seals the water passages... In case of a leak, it's function is to route the coolant outside the engine rather than letting it get into the oil...
To check the integrity of the gasket that seals the intake ports all you need is a vacuum gauge, if it idles 18in of vac or more you don't have a problem... Any leak that would lean the mixture enough to cause spark knock at open throttle is going to cause a very high idle(2000rpm or more)...
Reply #62
Quote from: TurboCoupe50;346172
Interesting. Would you happen to have a picture of this? I'll post a picture tomorrow afternoon of what I am referring to. Maybe you can confirm if it's the same thing.
Reply #63
Here ya go... Not all gaskets have them though, I have another set that doesn't...
Reply #64
These are the pictures of my intake where it almost looks like a leak. I put some rtv silicone there, just to see if the noise changed.. does that look like a gap to you?
Reply #65
Looks normal to me
Reply #67
Quote from: hypostang;346276
Looks normal to me
Agreed, gaskets aren't always cut straight across, so there often are small gaps... If you could insert a feeler gauge down into the opening, then there would be a problem...
Reply #68
Quote from: hypostang;344823
Nope, not necessarily in fact I have seen (heard) a lot of exhaust leaks that you could only hear under load ,
Well this is good news, kinda.
