Topic: A/C evaporator question.... (Read 3190 times) previous topic - next topic
http://cgi.ebay.com/ebaymotors/National-Refrigerant-12-1-12oz-Can-R-12-Made-U-S-A-_W0QQcmdZViewItemQQhashZitem19be594005QQitemZ110567702533QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
R-12 is readily available on ebay
Do not forget that Freeze12 and other similar "drop-ins" are technically illegal to use. Also, make sure none of it is in the system if you have a mechanic work on your car as it will contaminate his recovery machine.
Shiny Side Up!
Bill
I don't think they're illegal here in Canada (but not sure though). I do know those 1-lb over-the-counter R134A cans and any R134A DIY kits are illegal to sell here, but the replacements aren't...
Quote from: ProTouring442;330279
Shiny Side Up!
Bill
Where is this information from?
  Freeze 12 and Freezone  are EPA approved as long as regulations are followed ..eg: dedicated equipment , not mixing refrigerants etc...
There are shops around here that I know have used both with dedicated equipment .
Quote from: hypostang;330292
Actually, you appear to be correct. Freeze12 used to be listed as illegal on the EPA website, but I see that now it is listed on the "acceptable" list. If I recall however, you must use Freeze-12 specific fittings and label the system accordingly.
Nonetheless, it's still 80% 134A.
Interesting! Thanks for the heads up!
Shiny Side Up!
Bill
