Topic: 86 bird w/289 wont hold charge???? (Read 4144 times) previous topic - next topic
softtouch
is it the wire that is the shunt or the meter acting like a shunt.
I was under the impression the wire "to" the ammeter was the shunt.
in that drawing, they didnt zig zag either wire indicating one or the other was a calibrated lenght of resistivity.
what milivolt rating is the shunt?
Quote from: shameless;332657
mine has 3 wires on it, looks factory, but could be someones hack job.
If your car is really an 84 that someone swapped an 85 or 86 instrument cluster into, that would explain the 3 wires on the alternator. It may also explain why it doesn't work.
When you have a battery light the wire that is hot with the key on goes through the battery light before it goes to the voltage regulator.
Can you post your VIN number?
