Topic: Turbo Coupe Swaybar (Read 5481 times) previous topic - next topic
Turbo Coupe Swaybar
I've got the stock 1&1/8" LX sway bar on the front and a Turbo Coupe bar of the back of my T-bird. It handles good and I can slid the tail out a little on corners if I want.
As to the greaseable bushings I don't think they are necessary. I have non greaseable poly bushings and they don't squeak. The bushings came with a small tube of grease that I applied to the inside of the bushing.
Turbo Coupe Swaybar
Yeah it's not squeaking I'm worried about, its just that those happened to be the poly's that AZ carried so I'm wondering if I can use them with my stock brackets even though technically I will probably have to cut off the grease fitting...?
