Topic: Question on 1995 Ford Ranger 2.3 (Read 1379 times) previous topic - next topic
I have a question concerning a 1995 Frod Ranger 2WD with the EDIS 2.3.  My question is whether or not the vehicle should have an ignition control module or if it is incorporated into the PCM itself.
I'm receiving conflicting information concerning this.  Rockauto lists that the engine should have a separate module up to the 1997 model year.  Other sources state that the EEC-V equipped trucks do not have it and the last year for it was 1994.
Can anyone confirm?
According to Mitchell OnDemand it's integrated into the PCM
straight out of the ford manual :
During basic operation, the powertrain control module (PCM) (12A650) determines the ignition timing required by the engine (6007) and determines which ignition coil (12029) to use.
that would make me believe its integral to the pcm.
Quote from: V8Demon;328332
Can anyone confirm?
Have you checked out http://www.therangerstation.com? They have a lot of technical info on Rangers and some of it was very helpful with me working on my Bird.
Quote from: Watchdevil;328360
Yes.  Some of the contradictions actually occurred on that site?
After futher research and actually looking at the vehicle in question; it appears as though it's all integrated.
Thanks  ;)
ford-truck.com is a wealth of info for Ford trucks of all years and models.
