Topic: Keep blowing low side hose on ps pump (Read 1380 times) previous topic - next topic
Here is the problem I have done the 2.3 to ho swap on my 87 tc I put the v8 pump on with the res built in and did away with the res that was mounted on the fender well. Filled up the PS pump and it blew the low press rubber line comming off the rack. i got a new clamp and reinstalled the hose filled the pump back up and started the car this time it blew the hose off of the pump itself and it almost blew the same line at the rack as well. Am i missing something here when i did the swap should there be that much pressure on the return side?
87 TC
That seems kinda wierd. It is just the return line. I did not tink there was that much pressure comming back. I wonder of the new ho pump is putting out too much pressure to the rack and the week spot is the return hose? But you would think it would pop the cap off the p/s pump.
:burnout:
I didn't even have the cap on the PS pump
87 TC
never mind im a dumbass i didnt take the plug off of the return port on the new pump
87 TC
I will stay quiet then.......LOL.
:burnout:
