Topic: Key retainer? (Read 3022 times) previous topic - next topic
Key retainer?
Quote from: Watchdevil;327147
However all the pre-airbag Mark VII's which use the Fox steering column comes standard with a floor shifter and it uses a cable mechanism that installs in the slot above the ignition switch where a column shifter would normally go. This is also so for the 1989-93 Tbird and Cougar (which carried over the use of Fox steering columns) as I have examined many of them while harvesting parts.
So how does this work? Does it require the floor shifter to be in park before you can turn the ignition to lock?
