Topic: Well, I Wonder what this is? (Read 2194 times) previous topic - next topic
:wonders:
Wow!! a nearly intact build sheet , way cool :D
Flatten it out real good and scan it.
so, you got another fox? whats the VIN say, p62? tires are 215/70? soooo, LX car with 14" wheels?
where did you find the sheet? i found mine tucked behind the passenger c-pillar trim panel. i really need to get it laminated or sumthin one of these days
Did you buy the black sport from Clarksville craigslist ?
 And if so what kind of score did you get ?
That is the build sheet from my '97 LX. In my '86 Cougar, it was under the passenger seat. In this car, it was under the trunk carpeting behind the passenger side wheel well.
I've got a few other things on the plate before I start into more car stuff, right now.
Quote from: Scott D;326636
My poor build sheet was confetti when I found it under my front seat!
I never did find mine from the sport.
Quote from: Watchdevil;326669
That's the same way mine was, in the '86.
I'm going to make some phone calls to see if I can get more information on the sheet.
I have mine from the '97.... forgot to post about it.
Hunter found it when he was working on the car... his teacher told him they are supposed to remove them from the cars before they are taken from the plant. Mine is pretty much all in tact.
:cougarsmily:~Karen~
I have the one from my 88. It was under the passenger seat and is about 80% intact.
I havent found mine, would it be under the carpeting? any other places it could be?
Remember, if the women dont find you handsome, they should at least find you handy.
When all else fails, get a bigger hammer.
Chris
 93 cat rebuilt 3.8
check the trunk behind the liner
Quote from: merccougar93;326884
A Fox car? I'd check under the passenger's seat, first. Between the springs and the cushion.
An MN-12 car? I've heard of them being under the rear seat, under the carpeting in the trunk, and in a driver's side rear spring (of all places!).
Not under passengers seat, or the rear seat for sure, ill have to check teh trunk. thanks for the places
Chris
 93 cat rebuilt 3.8
