Re: Can a 3.8 column shift AOD go into a 5.0 floorshift car?
Reply #1 –
yes you can but you may have to drop the pan to change out the linkage bc they are differant that is the only thing that needs to be changed. or if you dont take the pan off maybe just change the arm. you will see what im saying.
