Topic: Frickity Frak! Turbo 4 or V8???????? (Read 11086 times) previous topic - next topic
yep. Go big.... I was going to go a 460 but I went a fuelie 5.8L swap. I still want to do the big block swap some day....But the 5.8L is soooooo much fun right now.
:burnout:
Or try a 4.2L out of a truck for a 3.8L swap? I think I saw someone do that swap before
:burnout:
This guy had a 3.8 cougar and went the 2.3t route. He said it was his daily and didn't want to modify it too much. He had an SVO that was mostly stock running in the 12's.
http://www.streetfire.net/video/turbo-cougar-vs-2005-stang-gt-5-sp_150789.htm
http://www.streetfire.net/video/87-cougar-turbo-23t-vs-03-mach-i-stock-mach_117724.htm
http://www.streetfire.net/video/87-cougar-23-t-5-sp-swap-stock-motor-turbo-sto_134888.htm
Makes me want to swap just listening to the turbo and open exhaust (against the Mach).
Make a turbo V8. Problem solved!
2002 Honda Civic EX
1984 Ford Thunderbird Elan
5.0 CFI, T5, Dual Exhaust
NICE! An old incon twin turbo 351w. Oh baby. Still call it a turbo coupe.
:burnout:
Quote from: T-BirdX3;323809
What's your goals? Is it going to be a DD?
Personally I see no advantage to putting a regular 5.0 in it. Yes they are decent reliable engines. But there performance and mileage are nothing impressive.
I don't know if you'll notice any difference in handling, the 5.0 bird I had seemed to handle as well as my TCs.
The 2.3T will be a little lighter, get better mileage, and outperform a stock 5.0 that came in these birds. And besides the grin that will be on your face when the boost kicks in will be the best part.
But that is just my opinion. :burnout:
I've seen many stock TC's running the same 1/4 mi times as stock SO 5.0 birds.  I've even seen modded TC's running mid-16's.  Both SO and HO 5.0's can turn some really good MPG numbers with the right gear and driving style.  Plus they're a bit more reliable and much cheaper to mod and maintain.
I say 351w FTW!
Good luck
-Don
Quote from: Eliminator;323887
. A friend suggested a 4.0L V6 out of an Explorer or Ranger (OHV not SOHC) which is basically the esshag V6 anyways.
You definitely want the SOHC if you were to go that route. I have the OHV in my explorer and it is an absolute turd. 160 hp, 225 tq. It will get out of its own way up to 30 mph, but otherwise, forget about it.
The SOHC explorer motor has 205 horsepower (5 less than the 5.0) and it's faster than the 5.0 explorer. That's stock, mind you.
-'88 Tbird 3.8
-2012 Altima 2.5 BASE.
Future: Budget 5.0 300 HP.
Quote from: 86caprirs;326251
Agreed. Or just stroke the current 3.8L to 4.0L. I'm not sure what would be needed for the Fox cars to make the swap, but the MN-12 cars have lists available on the interweb.
Gumby is right ( I had a duh moment) the Cologne V6 is even worse than the Esshag. I pretty much made up my mind. Turbo 4 5 speed. My buddy really knows how to extract power from the 2.3 (he said 500, I said um NO). Thanx for the input. I did like the Turbo V8 suggestion :)
All this engine talk excites me... :burnout:
Tmi, wd t m i!! Lol
Quote from: Eliminator;329614
:burnout:
muahahaha, now that you've joined us, there's no escape!
__________________
Twin '85 TCs
White/ Grey 2-tone
lol ive joind ya and now leaving with 351 power lol.
Got that fox rash again!
-Resident smartass! :ies:
I bought an 87 TC to strip out and put into the 88 LS
Here you go:
