Topic: WTB: C3/C5/AOD Floor shifter w/cable (Read 1947 times) previous topic - next topic
I need a C3/C5/AOD Floor shifter and cable assembly. Want to be able to shift my 4R70W.
I believe the A4LD was used in the auto TCs.
Quote from: 88turbo;323186
I have one of each shifter if your interested.
I'm interested. Do you have the shifter assembly, all fasteners and the cable?
How much shipped to 35758?
There's a TC at the "yard" over here. I'm pretty sure it still has the shifter. Interested?
1979 Ford Fairmont
[/B]
Quote from: 88turbo;323666
let me check when we get back home. should be sometime tomorrow.
What's the verdict?
Quote from: 32VFoxBird;323609
If 88turbo doesn't have one, I'm interested!
Sorry for the slow reply, limited internet access currently.
I have the shifter from my red Auto TC complete with the cable. I am pretty sure I have the bracket and TV cable also.
I am still unsure of which shifter you are wanting, I have both with cables and hardware TV cable for auto TC and shifter cable bracket for TC but I dont have the bracket for the 5.0 shifter cable. let me know which one your after and we will work something out :D
There is an auto floor shifter at U-Pull-It in Rock Hill, SC. I saw it yesterday while looking for some parts. It's a Sport with a Turbo nose panel. I was tempted to get the turbo nose panel but the back edge of the panel where it meets the hood has a chunk out of it where someone took the hood loose and carelessly dropped it down so the hood latch took a chunk out of it.
I've got an auto shifter, cable brackets etc from my 88 xr7 aod.  PM me if interested.
Quote from: 88turbo;324172
I want all the shifter hardware to convert a column shift to a floor shift. C3, C5, and AOD trannies all have shifters with 6 detents, which is the same number as the 4R70W. (Although the 4R70W goes P-R-N-OD-2-1, which no Fox tranny does.) A4LD trannies have 7 detents, so I don't want one of those.
I think all the hardware between transmissions is the same except for the shifter mechanism. If true, I can use the hardware from any Tbird/Cougar, but need a shifter from anything but a A4LD (Turbocoupe).
Does that make sense?
PS I've haven't really had internet access for the previous week, so my replies have been slow.
now i understand that you need one from a sport or XR7  and I have one with all of the hardware and cable but no tranny bracket. make an offer shipped and its yours
