Topic: Subframe connectors (Read 2459 times) previous topic - next topic
Subframe connectors
Are there any ready made connectors for tbirds?
Subframe connectors
competition engineering are a pretty close match.
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Subframe connectors
They are made for the fox body chassie.  I would buy something like a UPR set
 that are "FULL LENGHT"  set.
Subframe connectors
Does anyone know if the MM Full length Mustang SFCs will work?
Subframe connectors
Buy some 1X2 square tubing. The mustangs have curves under the body where our cars are straight. Someone on here said that they bought some MM ones and got them to fit after beating them straight with a hammer. Also, if you have to get some for a mustang, the fox's might be to short.
Subframe connectors
Copy all...Thanks!
Subframe connectors
I'm the one who beat the MM full length nearly straight to fit my car.
Subframe connectors
1x2 tubing is the way to go. You'll need about 5 feet per side.
Subframe connectors
Daminc, I like what you did with the SFC and jacking rails. Are the rails 1 x 2 also?
Subframe connectors
rails are 1x1 and the main frame is 2x2. the plans are floating around here somewhere. lol
Subframe connectors
So thats the recipe! If the plans turn up please pass on. Thanks!!
Subframe connectors
it should be posted in the project thread..... I think I posted it for christmas 2008
Subframe connectors
here it is. It wasn't christmas 2008
top of the page
http://www.foxtbirdcougarforums.com/showthread.php?p=232586&highlight=plans#post232586
Subframe connectors
You're awesome! Thanks!!
