Topic: fuel sending unit (Now with py pics) (Read 3634 times) previous topic - next topic
it use to i changed the little brown box behind the glove box. i can't  think of the name of it but thats your problem there.
Quote from: Cougar8775;322069
now was your low fuel light staying on even with a full tank? i know from time to time mine does and im unsure how to fix it.
ask clintd about the one from his cougar they should be the same.
now that you see the float on the preformed wire,,
you can imagine how furious i was when i went back out to the garage and found my boys (very very young at the time) fighting over the sending unit.
one tugging on the top and the other having a dead mans grip on the wire / float part.
i had to guess how to bend it back.
so..........as I might request for the sake of documentation..........
would you please measure the angles of the float wire part?
as you can imagine, my white coug gas guage use to be perfect.
it appears what i see there in the pics is a 45deg on the resistor side and a 135deg on the float side  (or 45 inside, 45outside angles)
jcassity,
the next time i got the tank down i will do that. just didnt think of it when i had it out.
