Topic: Minimal Heat (Read 763 times) previous topic - next topic
Minimal Heat
I did a quick search and didn't see much on this topic, so hopefully it is not totally a repeat.
The heat in my car not working properly. It has the electronic automatic control. The fan blows but the air coming out of the vents is not Hot. I would say it is about 10% of the warmth it was last year before I put the car away. I have checked the vacuum line going through the firewall and replaced the heater control in the dash. I believe there is a little vacuum actuated door in there somewhere but not sure where to look. Any ideas on where to look next?
Thanks,
Cam
Camertbird
1986 Thunderbird élan
Best ET 14.62 @ 94.20 mph
306ci HO, full length 1 5/8” headers w/2.5” dual Flowmaster exhaust, 8.8” Turbo Coupe rear axle, 3.73 gears, AOD transmission w/Bowman Electronics shift kit, B&M ProStick shifter, 16x8 American Racing wheels on 225/50 R16 tires, Mach 1 hood scoop
Minimal Heat
Possibilities:
--Blend door actuator
--Clogged core line
--Stuck thermostat
