Topic: My new invention for the body moldings (Read 9333 times) previous topic - next topic
I was a little skeptical when I first saw these, but that looks fantastic painted. It really looks like a proper stopping point for the trim. Great job.
87 Thunderbird LX
65mm tb, exploder intake, iron gt40 heads, 1.6 rr, a9l mass air swap, 9.5" Billet Dirty Dog TC, Built AOD, 4.10's, 31 spline TLoc, Superior Axles, full sn95 five lug swap.
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Looks good. I left the hard plastic sections on mine and deleted the rubber sections. I didn't mind the look of the trim, but it got a little distorted when I took it of to paint the car so I just decided to leave it off. Has anyone ever seen any nos pieces for sale?
Quote from: bryan163;366609
There is any easy fix for the warped molding. If you remove the aluminum backing from the vinyl side molding it will lay flat again. Then all you need is some heavy duty 3M molding tape and you're all set.
I will definitely give it a try. I didn't know there was an aluminum backing. I gotta go dig those out of my garage and revisit this. It really doesn't look bad with the moldings terminated at the wheel wells either though.
looks good
2015 Ram 3500 MegaCab Diesel
1986 Thunderbird Elan 302 Crate, x303 heads, e cam, 24lb injectors, gt40 intake, WC T-5, TC rear w/ 3.55 gears, CHP control arms,cobra r wheels.
Just came across this thread.. this is amazing!  I would love do have something done like this for my rear bumper, but I'm not very.... "crafty".
'88 Thunderbird LX
Engine:  FR B303 cam, GT40P heads w/ Trickflow valve springs, Explorer upper/lower intake, SR cold air intake w/ MAF
Exhaust:  shorty headers, BBK O-R X-pipe, glasspacks w/ turn downs
Misc:  8.8 rear, Saleen SC replicas 17x8/17x10, Mach 1 front springs/SN95 rear springs
'74 F100 Custom 351W
I think you could do something similar with the stock plastic trim cut down with a hack saw and some epoxy.
I like this nod,,
missed this thread somehow
Quote from: Haystack;453231
Good point.  Might be a cool project for my '88 in the future.
'88 Thunderbird LX
I remember seeing this, never thought to comment. Calls to mind old wraparound bumpers that did just "end" but with a rolled/tapered finish like that. Very factory-appearing!
i like it alot. was it C&C machined or did you just get fancy with an angle grinder?
 either way, very impressive work!
Port-a-band saw and bench mount belt sander
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
They took about 1-1.5 hrs each,  funny thing is I thought the other 3 would be easier. Lol
So the answer is heck no...how much are they worth?
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
