Topic: What spark plugs do you recommend? (Read 2430 times) previous topic - next topic
Re: What spark plugs do you recommend?
Quote from: Manson
what was the run? get into 11s yet?
I been layin off the giggle juice, it was a slightly improved 1/8 mi NA run(8.41). Prior my best was a 8.42 the night it went 13.11. Gonna play with the chip I have again, to see if it will go 8.30s. Maybe it has a 12 sec NA run in it... :crazy:
I put platinum Autolites in my white stock 87 XR-7 and it developed an occasional miss.
I put Autolite copper cores and the miss went away.
I used Bosch Platnum in my 87 3.8 and they lasted a few years replaced with Bosch +2's that seem to work well. As far as wires go, I've been through a few sets, apparently the 3.8 is rough on wires. Right now I'm using the best Bosch from Auto Zone and they seem to be the best lasting so far. They run about $40 per set. When these go I'm thinking of going for the Ford Motorsport. Apparently they have a set for 3.8, one the few items they stock for 3.8's
make sure its for your year 3.8L, because the later model stangs use DIS
you could buy a set for a 5.0, and use only 6 of the 8
