Topic: How do you swap the a/c evaporator? (Read 4555 times) previous topic - next topic
They made them that way, because they didn't expect the cars to be around long enough to repair them.
Think about it. These cars are getting pretty old, and we keep putting them back together like they're only 10 year old cars.
How often does an evaporator fail?
I'd clean it out with compressed air, water, and such, get it good and dry, and reuse it. Hell with cutting up a heater box. Been there, done it...wasted a good one. F*ck a bunch of that.
The one I have now is good ( I DO know for a fact) and when I finish things up, the inlet/outlet for the evap will be plugged off, in case I ever put AC back in.
I'd clean the thing up really good before I'd hack a box up, Vinnie. ;)
I can try to blow it out and see if there's anything that comes out.As I stated,it's been open for 3 years,and I know a lot of moisture has gotten in there over that time.
Then I would blow it out... Unpack that compressor and put it to good use, my good man...
So,you think after all this time it would still be good?
By the way,I got the compressor out and I'm getting it ready to clean up and detail.I smoothed the mold lines on the bracket,painted it with the charcoal gray whel paint,and installed a new steering pump and stripped and repainted pulley.I wish I could show pics,but for some reason,I can't upload pics on this computer anymore.When I find a way,I will.I've been making progress and can't share.
you could blow it out, and then pressure test it for leaks...
You may want to try to eye ball in there to see if any bugs have built a copuppies in there before you blow it out.
hmmmm..... good point
The evaporator does not absorb moisture,as long as you blow it out and there are no holes in it, it will be just fine.
Your reciever/dryer is what cannot be left open to the elements as it has a moisture absorbing desecent bag and would be no good if left open.
The receiver/dryer is brand new with the lines and capped from the factory.I HOPE this thing can remain in the car.I'd love to not have to pull the dash.I have too much going on.
Well, I'd give it a hell of a try first...easier to clean it out (or try to) than to pull a dash, heater box, etc.
Good luck man...let us know.
I'll post the findings....eventually.
