Topic: Fuel pressure questions... (Read 834 times) previous topic - next topic
Edelbrock 600cfm. Just curious what the fuel pressure should be ?And what are the problems associated with too low of a pressure ?
Going over my engine and found that both carb adjustments were way out of balance and running rich. Now I'm seeing a fuel pressure reading on the regulator of 3.5 . Seems low to me. Would this account for a "falling on it's face" feeling in higher rpms ?
Thanks
88 Sport ,306 roller block, flat tops, ARP rods and bolts, Compcam 533 lift/ 270 duration, roller rockers, ported 351w heads with 1.94 - 1.60 valves, 550 springs, 600cfm carb , full length headers, 2.5" dual X-pipe exhaust, MSD ignition, Hughes built C4, Weld Draglites, Tracloc /Richmond 3:73's
definately. should have enough pressure to keep the bowls full. that will vary on application. Average pressure would be between 4 and 7psi.
1979 Ford Fairmont
[/B]
Thanks, I'll be bumping it up .
you might also check the edelbrock website for some of the setup and troubleshooting or the manual if you still have it.
Quote from: 88turbo;317526
Just downloaded the manual. Looks like I should be at 6 to 6.5 .
Yea, set it at 6lbs and you should be good to go, I run my big block 472 at 7.5 - 8lbs
