Topic: Washer Fluid in-line filter? (Read 2433 times) previous topic - next topic
Hey all, I was cleaning up all the leaves/etc from my cowl area and realized there was a leak when I ran the washer fluid pump.  The leak was right at the in-line filter that's near the wiper motor, at the firewall.
I tried to take a better look at the leak, when I did the filter broke apart.  One nipple at the end snapped inside the rubber hose. Any ideas where I can find another filter?
It's an '88 Cougar.
pro-five-oh
Mine got all gummed up. Ended up just removing it all together.
1984 T-Bird Elan 5.0 (sold)
1994 T-Bird LX 4.6
2009 Dodge Charger Daytona 341/400
2013 Camaro SS
That's what I've been doing, and I guess I'm okay with it.
But I kinda want that thing back. :)
pro-five-oh
The ones in the boneyard today we're all gummed up too. Where to get a new one is the key???
1994 T-Bird LX 4.6
2013 Camaro SS
I don't even know if the washer pump on mine even works as I haven't used it in almost 7 years. Hell I used the wipers last year for the first time in 6 years:hick:
I think that other 80's Fords have the same filter.
It's not a filter it's a one way check valve.
It allows fluid flow only in the outward direction,it keeps fluid in the line not allowing it to freeze.
You don't need it.
Quote from: dominator;317597
You don't need it.
Ah, that's what it looked like!  I wondered if mine cracked because it actually froze in Houston and I had too much water in my system. Hmmmph.
pro-five-oh
Quote from: thunderjet302;317560
Gotchya beat, there hasn't been fluid in my washer bottle since the 5.0 was installed in '99... I have used the wipers a few times, rained all the way to Carlisle a few years ago...:mad:
You don't need it.
It also keeps fluid in the line so that you get instant fluid the moment you activate the washer switch. These are sold as a HELP! item at most auto parts stores.
Quote from: TurboCoupe50;320566
Driving to Carlisle in the rain is a right of passage......And it really sucks on drag radials.....
The only reason it has washer fluid is because the bottle was full when I bought the car:hick:
